跳转到主内容
加入维修社区 - 创建账户
Linsay 触控屏平板电脑 F-7HD2CORE 型号具备阅读、拍照和网络连接功能。
Why won't my Linsay Tablet turn on?
I recently purchased a Linsay Tablet Model: F-7HD2CORE a few months ago and now it won't turn on! I was using it to read and surf the web for approximately 4 hours and it suddenly turned off. Is my device broken or can it be fixed?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 5
1条评论
I bought a LINDSEY TABLET and the first one worked about an hour before it wouldn't come on again,,,SAME DAY I GOT IT!So after it wouldn't charge I sent it back,they sent another one...and it worked for about two months! It won't charge or come on.....smh
完成的
添加一条评论
8个答案
已选择的解决方案
The Linsay Tablet Model: F-7HD2CORE has a battery life of approximately 4 hours, so it is likely that you need to charge your device. Plug the tablet into a power source and allow it to charge, then attempt to turn on your device again. If your tablet's battery life becomes an issue, you may need to replace the battery.
For more information, see our troubleshooting page.
这个答案有帮助吗?
得分 1
添加一条评论
最有帮助的答案
After turning on my Lindsay tablet F-7xhd, I'm giving the red pixel with the lightening bolts on the screen and unable to do anything
这个答案有帮助吗?
得分 2
添加一条评论
my tabley will not turn on it will not charge can you help
这个答案有帮助吗?
得分 0
3条评论:
My tablet could not charge
完成的
mine won't charge too
完成的
They are a piece of crap......I gave up and Bought a SAMSUNG
完成的
添加一条评论
I just opeed the tablet how long, must it change in order to turn on?
这个答案有帮助吗?
得分 0
添加一条评论
Well… my Lindsay tablet won’t let me get into it after I turn it on to the lock screen, a few months ago, I cracked the screen and now I don’t know what to do with it. Do you have solutions on how or where to fix it??
这个答案有帮助吗?
得分 0
添加一条评论
My linsay wont come on after only a few months of owning it. Any answers?
这个答案有帮助吗?
得分 0
1条评论:
what would it cost for a 10 inch
linsay battery
完成的
添加一条评论
I. Bought my wife a 7". Linsay tablet 3 months ago now it won't come on at all
这个答案有帮助吗?
得分 0
1条评论:
The first one I bought came on once and that was it! Sent it back and the replacement lasted about a month ..and it too died! THEY
ARE GARBAGE!!!!!!!!!
完成的
添加一条评论
I also have a Linsay tablet, it's fairly large I sometimes use it in bed when I am reading. Today I turned on my tablet and it begin twitching and when it shuts off or "sleep" the screen comes back black?
I am not sure if the screen is damaged or not, my screen isn't even cracked.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Lindsay Byrnes 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 4
过去 30 天: 70
总计 4,628
