跳转到主内容
The Microsoft Surface Pro 2 is a Tablet/Laptop fusion that was released in 2013. The Surface Pro 2 is the successor of Microsoft's Surface Pro and uses Windows 8.1 through Windows 10.
40 个问题 查看全部
Power button no longer works
Hi
Came to power on my surface today and the power button no longer clicks meaning I can't power it on, would it be possible replace the button?
Thanks
回答此问题 我也有这个问题
这是一个好问题吗?
得分 5
添加一条评论
6个答案
最有帮助的答案
Sorry, I never updated this with the solution that I came up with.
I was never able to get a replacement power button, so I removed the button entirely and there is a direct line of sight from the old power button hole to the ribbon connector on the motherboard. So you can short it with a screwdriver to mimic the button press.
Worked for 2 years starting it every day with a screwdriver across the pins!
Hopefully that helps somebody out.
这个答案有帮助吗?
得分 2
2条评论:
thank you for the update. Do you have any picture of it? i have the exact same problem
完成的
How did you take it off
完成的
添加一条评论
I had the same problem, a clean was enough to get it working again
unfortunately my my touch was damaged when I opened the screen
这个答案有帮助吗?
得分 1
2条评论:
is it work well now?
完成的
it looks the power botton is soldered to the palstic panel. after take it down is it possible to solder or glue it back?
完成的
添加一条评论
Power button assemblies are available on ebay, but to fix it- you need to completely remove the screen/digitizer- not an easy task and not recommended unless the screen is already broken and needing replacement anyway.
这个答案有帮助吗?
得分 0
添加一条评论
Could someone be more precise as to the model number for the Power button assembly for the Surface Pro 2? I’m having trouble finding it on eBay. Hopefully they’re still available these several years later.
这个答案有帮助吗?
得分 0
添加一条评论
to whoever reads this, I have just discovered that my surface pro2 also has the same issue and the only way I can get it to startup is to hold both buttons and do a hard reboot. I am going to try and put my pro into sleep mode instead of switching off completely and see if I can overcome this problem. I can easily guess that taking it to BestBuy/ Currys uk that it would be too costly. I might have to do a trade in as the self fix option is not suitable or might not work even afterwards. Sorry I could not come up with a better answer.
这个答案有帮助吗?
得分 0
添加一条评论
Having left my surface pro in sleep mode and gone back to it several times, I have been able to either click the mouse or tap the cover to activate it. Hopefully this will allow me to use it without buying another one.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Sam Wildig 将永远感激不已
浏览统计数据:
过去 24 小时: 8
过去 7 天: 23
过去 30 天: 76
总计 8,871
