broke the power button flex cable
hi,
i snapped the thin flex cable for the power button when trying to replace the screen. is there a part i can replace? or will soldering work?
Soldering skills of medium level will be required and a good iron with small tip (silver bearing (preferred) solder with good non acid flux as well). I would not advise anyone who does not have those skills to attempt repair unless you don't mind F@i& up the whole board. The ribbon can be bought online but it does require soldering.
这个答案有帮助吗?
过去的24小时: 1
过去的7天: 2
过去的30天: 3
总计 2,544
I have this same issue. I have ordered a replacement cable. Does it require soldering or will it just clip into place?
由 Colin Stennett 完成的
