跳转到主内容
Nokia Lumia Icon is a high-end smartphone that runs Microsoft's Windows Phone 8 operating system. It was released by Nokia February 2014 also known as Nokia Lumia 929.
Touch not working after new LCD install
I am a professional cellphone repairman and this issue has me perplexed. I bought an entire frame/lcd/digitizer replacement combo and very carefully transplanted all the componets. When I powered on the device the touch was not working. I figured the part was defective so I reinstalled the old LCD/digi/frame and now the touchscreen does not work on that either! There is only one cable that plugs in to the main board for both the LCD and Digitizer and I have absolutely made sure it is completely plugged in. HELP!
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 5
2条评论
Hi Daniel,
I also had the same problem identical to yours, but I can't find out the problem. I have done hard reset with the keys in addition to reset and update with windows device recovery, but getting no positive result.
Are you solved the problem?
thanks
Dave
完成的
Same issue here with nokia lumia icon. The different screen voltage requirement should be published better. I paid 82 bucks for the new screen and frame assembly. I'll try to return it for the right one.
完成的
添加一条评论
5个答案
已选择的解决方案
Hello I m also a proffesional Technica for Smartphones.
At first this thing happened to me too... after the repair the Touch didn't work.
After long research i found the reason. Nokia produced 3 different types of displays(2V/5V/7V)
You can check the Voltage on the inside of the Display(right bottom).
这个答案有帮助吗?
得分 7
5条评论:
So why doesn`t the original work anymore?
完成的
oh wow, I got lucky to get the right one from the get go.
完成的
After two attempts, The second screen was perfect
完成的
do you mabye have a picture of the location where it says the voltage ?
, lumia 930
完成的
i have something like this - T7-1 V5.0 on the new one, and H3,2V5.0 on the old one. Are they both are 5V? i'm ask becouse it dont work.
完成的
添加一条评论
Try to do a hard reset, has helped with alot of lumias for me
这个答案有帮助吗?
得分 2
1条评论:
Kaur K you're right, but you need to explain what is a "hard reset" with the Lumia 930 : Just need to press Volume Down + Camera button + Power button in the same time during few seconds and voilà!
完成的
添加一条评论
I replaced twice the glass frame for Lumia 535. First one didn't react to my touch after replacement. I discover later there are different models of glass frame for Lumia 535. The first seller just said it was for Lumia 535. But when I checked orginal glass frame, there was reference number:CT2S1973FPC-A1-E which wasn't corresponding to my first purchase (CT2C1607FPC-A1-E). Someone said there is another reference number for Lumia 535, so total would be three kinds. Make sure you buy the replacement piece not by the telephone model, but also exact reference number. The reference number is visible in the back connection between the glass frame and the panel connector. Good luck for everyone.
这个答案有帮助吗?
得分 2
添加一条评论
Simple fix! Take back off phone , insulate the metal parts with insulation tape. Careful not to insulate contact points.
这个答案有帮助吗?
得分 0
1条评论:
Which metal parts should be insulate?
完成的
添加一条评论
Is there anyone who has this issue with the original digitizer not working after attempted repair, and successfully made it work again?
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Daniel 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 8
过去 30 天: 35
总计 10,113
