跳转到主内容
Apple发布于2012年9月12日的第六代iPhone,维修时与前代型号一样,需要螺丝刀和撬棒。iPhone 5以多种版本销售:通讯制式有GSM/CDMA;存储容量有16/32/64G;颜色有黑/白。
2522 个问题 查看全部
What to do when my iPhone pentalobe screws are stripped?
I saw someone else has written this question but the problem is, I don't have have soldering iron as they asked. I do not know what to do and I have bought a brand new housing for it which will be useless if I am not even able to unscrew the first screw. I need help as soon as possible that does not involve any form of like technical tools and I am not very experienced at these things.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 3
添加一条评论
4个答案
最有帮助的答案
Try these removal methods:
Rubber Band Method – Put a rubber band in between the screwdriver and the stripped screw. This will give you a bit more grip and hopefully remove the stuck screw.
Super Glue Method – Put a small amount of super glue in the stripped screw. Hold your screwdriver on the screw for about 20 seconds and then try to unscrew it.
Small Flat Blade Method – You can also TRY to remove the stripped screw with a small flat blade screwdriver. Tilt the flat blade screwdriver at a 45 degree angle and try to get a grip inside the stripped screw head. Slowly and with pressure being put into the screw, turn counter clockwise.
这个答案有帮助吗?
得分 2
2条评论:
Success!! thank you thank you thank you!!!
完成的
Your welcome bamaaeiou, glad to hear it worked for you.
完成的
添加一条评论
Try other screwdriver even the slotted screwdriver.
这个答案有帮助吗?
得分 1
添加一条评论
Got IT! Found the answer on post from BurnieG. Tried the rubber band, tried the super glue and then moved to the flat screwdriver. Between all three, that lil bugger screw is free at last!!
这个答案有帮助吗?
得分 1
添加一条评论
It seems apparent that you are in over your head. You should not try to repair things like this. Pay someone to fix these things for you.
这个答案有帮助吗?
得分 -1
添加一条评论
添加你的答案
nihalsoofi 将永远感激不已
浏览统计数据:
过去 24 小时: 7
过去 7 天: 31
过去 30 天: 95
总计 6,934
