跳转到主内容
Apple发布于2012年9月12日的第六代iPhone,维修时与前代型号一样,需要螺丝刀和撬棒。iPhone 5以多种版本销售:通讯制式有GSM/CDMA;存储容量有16/32/64G;颜色有黑/白。
iPhone 5 boot loop
I have an Iphone 5 that had minor water damage. But was all cleaned out and was working great.
Then a few week later it was bent (as seen in picture) when plugging it in the apple logo appears for about 4 seconds then the phone shuts of are repeats the process. Then I tried to put the phone into recovery mode to update or restore to phone and i got the error code 21. So I opened it up to find a broken component on the board (as seen in the picture). And i need to know if it is replaceable and what it is.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 2
添加一条评论
4个答案
In the picture, are you talking about that piece near the bottom middle of the board w/ a white circle? If so, that's an inductor. These are specs for it 2.2UH-20%-1.45A-125MOHM if you can find one.
How did you clean it out? And did you remove the shields too to check for any damage?
这个答案有帮助吗?
得分 0
添加一条评论
Try a new battery that has a charge first.
这个答案有帮助吗?
得分 0
添加一条评论
I have this same problem . The Apple logo appears for 10 seconds. I replaced the battery and the same thing happens. I do not think I had any water damage but it is possible. Any thoughts, anyone?
这个答案有帮助吗?
得分 0
添加一条评论
Hi, anyone knows the exact name of the L2 component?
Thanks
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Ryan Ferris 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 1
总计 518
