跳转到主内容
加入维修社区 - 创建账户
在与惠普合并前,康柏电脑制造全系列的笔记本电脑。 现在他们由惠普制造,拥有最基础功能的电脑。
Is it the LCD
I have a Compaq Presario V5309wm with trouble the display.Most of the time the view is good for the fist 1.5 inches and then It goes dark. The further you down the screen it changes to white,, if I am looking at the BIOS (External Monitor is perfect.) If I am looking at windows the instead of the lower part being it is is vertical lines of color, (External Monitor remains Perfect). The lines of color appear to change as the colors change on the monitor, yet it does not appear to have any intelligence driving the horizontal scan.
Is it the LCD, INVERTER, MOTHERBOARD, or something else? How Can I tell?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 -1
添加一条评论
1个答案
已选择的解决方案
Being that it works perfectly in an external monitor u can pretty much rule out the motherboard. I would first try to replace the inverter, if that doesn't work, then your display might need to be replaced.
这个答案有帮助吗?
得分 3
2条评论:
+ Ralph
完成的
I talked to Compaq customer and they are the only reason I even considered the motherboard. I did think the it would be the display. With many suggestions it was recommended that I should swap out by cost inverter, back-light and then the LCD. Thank you for the suggestion and I believe you are right. I will try to let you know as soon as I do. thanks 4 help
完成的
添加一条评论
添加你的答案
Johneasy 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 1
总计 1,423
