跳转到主内容
MacBook Air not charging, not turning on
Hi,
the Macbook Air 11" Mid 2011 is not charging the battery. The light of the Magsafe connector is always green. The computer will not start up with the Magsafe Poweradapter connected.
What I have tried so far:
  • used other power supply
  • replaced battery
  • reset SMC
  • reset PRAM
  • upgraded to Yosemite
After the battery change the computer will start up. But the computer will not charge the battery and the battery will run down even when the charger is connected.
Do you have suggestions on what I could change/check? (IO Board? Logic Board?)
Christian
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
Hi Christian,
I'd definitely check the I/O board first. It looks like the power from the charger isn't reaching the MacBook. Check the I/O board cable.
If that doesn't help, I'd also check the battery. It's pretty unlikely though, because the MacBook should run off external power if a charger is connected, no matter if a battery is available or not. But you never know.
这个答案有帮助吗?
得分 0
3条评论:
Thanks! I will check the cable and the IO Board.
Btw, with a multimeter do I have any luck in diagnosing the problem? I would probably just switch it but it is not so easy to find one in Germany.
Christian
完成的
Same problem here, did you get to fix it?
完成的
Same problem here. Did you get to fix it?
完成的
添加一条评论
Hey Christian,
Am facing the same problem! Did you get to fix your MBA?
Tyson.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Christian van der Leeden 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 3
总计 581
