跳转到主内容
The third generation of the Samsung Galaxy Note phablet series released September 25, 2013. Identifiable by the model number N9005.
Note 3 imei certificate fail
I can not make calls or receive it says fails to register on network I upgrated also to version 5 . The phone was root before and also was having the same problem ( I try and manual to register it finds the local providers but it's fail to register , I try and few SIM card )
When I try the code *#0011#
The
Imei certi : fail
回答此问题 我也有这个问题
这是一个好问题吗?
得分 6
添加一条评论
4个答案
i am having the same issue if find how to fix it pls send me a way on my email and ty my email anas_mukresh_1996@hotmail.com
这个答案有帮助吗?
得分 0
添加一条评论
1. Please make sure the email account is correct when you registered samsung account.
2. Land on the email, check the junk mail, check whether the validation email be intercepted.
这个答案有帮助吗?
得分 0
添加一条评论
my phone imei null..phone is root
这个答案有帮助吗?
得分 0
添加一条评论
Buy a chimeratool 3 day license. Activate usb debugging under developer options(tap buld number about 7 times). root the phone and after that do imei repair with the original imei under the battery.
other alternative is to make a new falsh with odin. you can get the firmware from sammobile . this method will delete all your information so make sure you do a backup first.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
christis1975 将永远感激不已
浏览统计数据:
过去 24 小时: 3
过去 7 天: 7
过去 30 天: 18
总计 5,924
