跳转到主内容
Apple发布于2012年9月12日的第六代iPhone,维修时与前代型号一样,需要螺丝刀和撬棒。iPhone 5以多种版本销售:通讯制式有GSM/CDMA;存储容量有16/32/64G;颜色有黑/白。
2522 个问题 查看全部
Stuck at Apple logo boot loop after battery replacement.
I recently replaced the battery on my iPhone 5. I thought everything went great until after reassembly rhe screen would not boot. After a lot of trial and error I realized I damaged the screen so I ordered a replacement screen and repaired that as well. The screen now works but when I try to turn the phone on the apple logo displays then the screen goes dark. I tried charging it and the same logo, blank screen happens. I tried it resetting it and the "plug into iTunes" image appears but when I plug it into the computer it does not recognize the device. I swapped the old battery back in and the phone boots up just fine. Any ideas, or is the replacement battery just faulty?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
3个答案
If the phone starts up with the old battery and not the new one then the new battery is definately the problem. I have had lots of issues with "new" batteries.
这个答案有帮助吗?
得分 0
添加一条评论
I have the same Apple logo reboot loop with a iFixIt kit . . . any ideas to bring my phone back??
这个答案有帮助吗?
得分 0
添加一条评论
Defective replacement battery, you should contact iFixit for a replacement.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
mercedeslewis90 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 1
过去 30 天: 1
总计 1,134
