跳转到主内容
加入维修社区 - 创建账户
IBM 于 2003 年发布的一款坚固耐用的笔记本电脑,ThinkPad 品牌现归联想所有。
How to reset supervisor password
OK mother in law loaned out her old IBM r40 when it came back it had a password on it when asked the the person said humm I don't rember. Well now it ends up in my hands. I tried the clock battery removal no luck. It shows a it shows the IBM splash screen then goes to a lock with the number 1 next to it and I think that means its a supervisor password. Could just be a HDD not sure. But I do know thinks to the security chip I'm locked out. Any help would be appreciated.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 4
添加一条评论
1个答案
已选择的解决方案
Here is an IBM backdoor Bios password "merlin" all lower case no quotes...Let me know if it works...
这个答案有帮助吗?
得分 5
3条评论:
If not I'll look for a boot cd that you can download and remove the password with...
由完成的 分享
Here is something else you can try....
THE MOST EASIEST WAY TO BYPASS THE BIOS USER PASSWORD (not to enter the Bios but to enter computer Windows).
1.When you turn on the computer you wait until it say: “Enter Password”.
2.When the first step is done you press and hold End for about 3 seconds.
3.While holding end press Enter and you will be on your way to Windows.
由完成的 分享
Now if your not getting a prompt to enter a password, your hard drive could be bad. You then will have to connect it as an external drive to another computer and see if it is recognized, If it is recognized see if you can access files. If you can access files, then run a check disk..If it all checks out good, then it may not be booting up if the MBR (master boot record) is corrupted, then you will need to fix the MBR with a program.
由完成的 分享
添加一条评论
添加你的答案
edwarddugger 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 4
过去 30 天: 34
总计 10,166
