跳转到主内容
Sumvision Cyclone Micro Media Player offers support for USB storage devices and MMC/SD/MS/SDHC cards.
How to tear down so as to repair?
Hi,
The AV Port pin hole, Power Port and digital coaxial port to the Cyclone somehow pushed way inside and I cannot connect any cables to it. I don't see any screws on the Player.
How do I disassemble the unit to fix the problem?
Thank you.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
You need to pull of one of the plastic end plates and then the circuit board will slide out. If you have short fingernails you can grab onto the corners and just pull. Alternatively use a thin screwdriver to lever it open at the corners. Please see the attached picture.
However, this is a very complex double board assembled by a robot and is very difficult to repair. You can try to solder back the AV connector. If you do not succeed then you will need to buy a new device.
Kind regards
Chris
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Shiru 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 11
总计 378
