跳转到主内容
加入维修社区 - 创建账户
4英寸屏幕;多种颜色可选;共发布三款型号;闪存容量:16、32及64GB
My iPod Touch wont turn on and the home button is broken?
My Ipod Touch (16GB, no camera) wont turn on! It was fully charged, and I just used it and put it on sleep. I tried to turn it back on again but it wasn't responding. This has happened before, so I tried doing what I did last time, get into into recovery mode by plugging it in and holding down the home button and power button etc etc,
But
My home button has been jammed for several months. It wont click and its physically broken. I had been using assistive touch. I dont know what I can do? Maybe I could take it to an apple store and they will fix the home button so I can get it into recovery mode or is there another way? Please help.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 41
25条评论
I have tried to turn on my ipod so many times but it doesn't want to and I cant press the home button because it is broken. what do I do? please help me!!
完成的
I dont know what to do!!! My ipod screen cracked like 2 months ago and it worked perfectly FINE!AND IT WAS FULLY CHARGED this morning AND I WAS PLAYING ON IT AND IT SHUT OFF AND I STARTED FREAKING OUT! i have no idea what to do! Pls help!
完成的
I was playing clash of clans it shut off and im still siting here hoping it will work I will be taking it to the apple store I hope my iPod 5 gen will work
完成的
Yes omg. So last night I turned off my Ipod because I was going to bed. Then I remembered I wanted to check something. So, I tried the power button. But, I couldn't try to turn it on with the home button because it has been jammed for almost 3 months. So, please help I don't know what to do exactly and I'm freaking out because I know they say if it won't turn on then hold down the power button AND the home button. But, I can't really do that because I don't have the original home button, I have the one on the screen (idk what its called) So, please help. :(
完成的
@Random Channel @swat 100 @Emma peters @nataly
Try leaving your iPod alone, completely untouched, for a week, even a month, and the plug it in to charge again. But dont try to turn it on at all. Just leave it. Thats what i did. Good luck hopefully it works :)
完成的
显示更多的20条评论
添加一条评论
12个答案
已选择的解决方案
A few weeks ago . I was on my way to dance practice and my phone was perfectly fine. I was using it the whole time. Then i left it alone for a good 15 min and when my phone wouldn't turn on at all. There was nothing on the screen but it wasent my first time that this happen but. I was the first time that my home button didn't work. So i was crying and i was researching solutions to help me with my problem. And there were none i tried calling apple store and they didn't help at all. Then i tried to research again and i found a person that said to just leave your phone not charged for a day or a couple of miniutes . And i did that and the dead battery came up when i pressed the power button. I charged it and it working ever since then. Im very greatful that it works and i hope i helped people with this comment.
这个答案有帮助吗?
得分 22
27条评论:
I will try that!! Thanks!!
完成的
omgg asvad thanks sooo much you saved my ipod!!!! <3
完成的
ooppppsss i kinda just charged my ipod for an hour
完成的
thank you sooo much i thought i broke my ipod
完成的
thank god lol
完成的
显示更多的22条评论
添加一条评论
Leave your device alone uncharged for a day or two and then try the power button, it should show the dead battery icon, if so, charge it and it should go back to normal
这个答案有帮助吗?
得分 6
4条评论:
i have the same problem. my phone was working fine all of a sudden i go to check the time and it wont turn on at all. I even tried to see f it was dead but it wasnt. what do i do? Also my home button is broken so i dont know how to turn it on?
完成的
how do I make the battery run low? Do I keep cutting it off & on until I see the low battery sign?
完成的
My ipod will not turn on and I took some advice and left it alone to let it die and it has been a week now and it still wont say that it died. I don't know what to do! Ive tried many things and it still wont turn on.
完成的
Yes. This worked!
I have an ipod touch. My home button is broken. When I came home and tried to wake it up, nothing. Total blackness. After trying many things (including the tip about putting it in the freezer for 10 minutes) I just left it alone and let the battery drain. A day later, I tried to start as usual and ...... the dead battery icon came on. Oh, so happy! Charged it a few minutes and was back to listening to podcasts of Decoder Ring Theater while a fall asleep again.
完成的
添加一条评论
The cu-tip and rubbing alcohol method works. I once had a broken home button and tried this method and it worked thankfully. Put rubbing alcohol at the end of a cu-tip and then rub the cu-tip around the home button. This will help get any dirt and dust that might have been clogged. look at the cu-tip after, you will see dirt and dust and its just gross but this works and its easy
这个答案有帮助吗?
得分 2
4条评论:
this didn't work
完成的
Actually found another solution that I do aswell. Leave it uncharged for a couple days until it drains dead, then try turning it on and it will show up "plug in charger" problem instantly solved
完成的
how do I make the battery run low? Do I keep cutting it on and off?
完成的
@Nae To make The battery run low? I'd just leave it uncharged. I'm sorry I don't think I understand your question :)
完成的
添加一条评论
So this happened to me before with my iphone and you just keep it not charged for a day or two
这个答案有帮助吗?
得分 1
添加一条评论
You need to use a jailbreak tool to get into DFU mode without working buttons. Instructions can be found here. You do not need to actually jailbreak the device for this to work.
这个答案有帮助吗?
得分 0
5条评论:
EVERYONE I HAVE FOUND THE ANSWER TO EVERYONE PROMBLEM PUT YOUR IPHONE OR IPOD IN THE FREZZER FOR 10min set a timer when the 10 min is up take it out and plug it up to your charger this should work lik if this helps
完成的
I feel like this is gonna destroy my ipod lmao but im gonna just go for it
@ronell the great jackson 12
完成的
@spacedsmile Did this work, Jane?
完成的
@spacedsmile did it work
完成的
did it work? the freezer method?
完成的
添加一条评论
Hold the volume button down and the power button down at the same time it might not work because I don't know if you have to have a charged or dead ipod
这个答案有帮助吗?
得分 0
3条评论:
Volume buttons my bad
完成的
what does this do?
完成的
i dont think this works
完成的
添加一条评论
So this used to happen to me when my phone worked all they way. I'd be at a hockey practice, come back to the locker room, and it'd be completely off.
Sometimes they do this when they get too hot or cold.
Now that my home screen button is broken, it happened again. My friend told me it shouldn't matter if the button is broken, holding down the power and home buttons should work. And it did.
It happened again today and i sat from a good five minutes waiting for the apple logo to appear, but my phone is back on.
If the apple logo comes on and back off, put it on the charger. That worked this time.
这个答案有帮助吗?
得分 0
2条评论:
Do i hole down both home buttons ?
完成的
hold down both volume buttons ?
完成的
添加一条评论
do you think my ipod will turn back on today it turned off like around 11 in the morning
这个答案有帮助吗?
得分 0
添加一条评论
I have used different Apple products in the past and I've always had problems with them, but I have also used Android in the past and present, and I am and have had no problems at all. The Apple workers are not helpful in any way shape or form. So I definitely recommend Android. My favorite Android product is the Samsung Galaxy S7 Edge, it's waterproof and amazing. (It's also big but not too heavy) I have not tried the Galaxy 8 yet though, but from what I hear it is really good.
这个答案有帮助吗?
得分 0
添加一条评论
So do you guys know when you keep pressing your home button it turns your screen a different color? anyway so i accidentally did that because i was trying to get to the home screen on my phone but it wasn't working, and my phone turned completely off the screen went completely black. But when someone texts me or something my phone vibrates. please help me! I really need some solutions.
这个答案有帮助吗?
得分 0
4条评论:
@kasharac How many times did you click the home button, Kashara?
完成的
it's broken. i can't click it.
@akufygkhusbrg
完成的
完成的
wait for it to die then charge it
完成的
添加一条评论
It has been going on 3 years now and my iPod will not work. When I charge it it goes to the apple logo to a black screen and continuously does it. What should I do?
这个答案有帮助吗?
得分 0
1条评论:
replace the battery is step 1. battery's do in fact go bad.
完成的
添加一条评论
My iPod touch is not turning on and my home button do not work
这个答案有帮助吗?
得分 0
1条评论:
replace battery, while inside check your home button. perhaps replace that assembly also
完成的
添加一条评论
添加你的答案
Aravis 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 16
过去 30 天: 88
总计 100,389
