跳转到主内容
iPhone 3G是第二代iPhone。型号A1241,有8或16 GB容量,和炫酷的黑色或洁白的白色塑料背面。修复比第一款iPhone更简单。需要螺丝刀、撬撬工具和吸尘工具。
Problem with signal after replacing battery
hi, i need help. After replacing battery on my iPhone 3G american factory( i'm italian) it starts to have problem with signal that is the most time on No service. Only if i connect iPhone to the pc i have a bit of signal and can call. So i send it to a "repair house" that said to me there was a problem with the motherboard and it's impossible to repair. I think it's a lie because all works on my iPhone except signal. In your opinion replacing antenna can i solve problem? Thansks
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 -1
添加一条评论
1个答案
已选择的解决方案
maybe they don't know it better.
most "repair shops" have no good repair informations about the iPhone.
i think that nobody could give you a good diagnose without seeing it.
the problem occured right after you worked inside the phone - so no, i don't think that replacing the antenna is the problem.
i would check the connector first, than everything in the antenna circuit - but as i said - no chance to point out an exact problem without seeing a high-res/sharp picture of the logic board
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Toioski Toioski 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 1
总计 1,849
