跳转到主内容
The EOS 5D is a 12.8-megapixel digital single-lens reflex (DSLR) camera body produced by Canon. Released Q4 2005.
16 个问题 查看全部
Flash will not pop up
The flash no longer pops up, when it should.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
6个答案
最有帮助的答案
5D doesn't have a built flash.
这个答案有帮助吗?
得分 1
添加一条评论
Adjust the hotshoe. Loosen it off and check the contact in the middle, as is sometimes stays depressed/gets caught when you remove the external flash. The camera thinks it has a flash attached and prevents the pop-up flash from coming up.
这个答案有帮助吗?
得分 0
添加一条评论
The 5d doesn't have a built in flash. You need to fit an external flash!
这个答案有帮助吗?
得分 0
添加一条评论
Hi Sally,
The Canon 5D is a full frame DSLR camera and has no built-in flash. So, I am assuming you are talking about an external flash (like a Canon Speedlite) which you attach to the hot shoe of the camera.
Tell us more about the flash (brand, type, etc.) and what settings you used when the issue occurred.
这个答案有帮助吗?
得分 0
添加一条评论
i think u have to get a external camera for this device
这个答案有帮助吗?
得分 0
添加一条评论
Eos 5 film had a pop up, but not the 5D
Update (09/11/2022)
My Eos 500d has a pop up... Are you confusing the 5d
with the 500d??
这个答案有帮助吗?
得分 0
1条评论:
with the 500d??
完成的
添加一条评论
添加你的答案
Sally 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 5
过去 30 天: 5
总计 781
