跳转到主内容
Apple发布于2012年9月12日的第六代iPhone,维修时与前代型号一样,需要螺丝刀和撬棒。iPhone 5以多种版本销售:通讯制式有GSM/CDMA;存储容量有16/32/64G;颜色有黑/白。
2522 个问题 查看全部
details metal plate covering screen connectors
Curious the importance of this plate and the 4 screws holding it. If it were missing, does that present a problem?
thank you
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 -1
添加一条评论
2个答案
已选择的解决方案
No. The connector cover plate just helps hold the front assembly connectors in place on the logic board. Therefore a connector could come loose in the future requiring you to open iPhone and reseat the connector. If ever get the cover plate and the screws, be very careful to place the different screws into the proper locations. The screws are different. Wrong placement of the screws may severely damage the iPhone.
这个答案有帮助吗?
得分 3
添加一条评论
I doubt it would severely damage the phone to be honest if you put the screws in the wrong holes.
Yes, they may get stuck but as long as you could get them out you would be fine.
The only problem I could see with doing that is that you may not be able to fully re-fit the screen correctly but it would hardly be noticeable to be honest.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
berkley 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 2
过去 30 天: 2
总计 163
