跳转到主内容
加入维修社区 - 创建账户
The third iteration of the 10.1 inch Galaxy Tab tablet.
Why is my screen discoloured?
I went out for a bit came back and went to go see my tablet to realize the screen is discoloured like a fuzzy pink color and it looks like the screen is spazing but it's not please help I can't watch or do anything because my screen blurs out most of everything with pink I'm guessING it was because to much pressure put on it but I dont know please help!!!!
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 6
3条评论
How did you end up fixing it? I just woke up and mine is doing the same thing
完成的
The same way unscrew the back part
完成的
mine ended up turning black and i dont know what i should do
完成的
添加一条评论
3个答案
已选择的解决方案
Theres only one solution n its to take off the back cover n theres 3 cables going over the battery disconnect the far right one with the green strip of tape an reconnect an start ur tablet n it should be good....
这个答案有帮助吗?
得分 13
7条评论:
After searching the internet for weeks for a solution to this problem following your instructions worked.
I love you!
Months without a tablet have come to an end!!!
完成的
THANK YOU, THANK YOU, THANK YOU.
Simple fix and it worked!
-RJR
完成的
Just tried the fix....worked like a charm!! back up and running! no pink stink
完成的
It worked!!! Thank you so so much! You saved me a bunch of money ☺️ Also I used this site which has an image step by step guide that I found useful along with this info
https://www.sosav.com/guides/tablets/sam...
完成的
Hi I have the same pink fog on my Samsung J7 mobile. It's the model 2016 that you cannot take the back off. Any answers pleeeeeease. Thank you.
完成的
显示更多的2条评论
添加一条评论
Holy $@$* it worked, mine had a green tint or hue to the screen. unplug the battery connector, wait a minute and plug back in.
这个答案有帮助吗?
得分 1
1条评论:
Didn't work for me...thick blue band visible towards left from the centre of the screen...
完成的
添加一条评论
I really want my money back for this tablet. The hospital broke my 1st Samsung tablet. So I invested in a rca tablet. I felt as if it didn't work like my last Samsung. Nevertheless, I brought me a new Samsung tablet for Christmas but I got covid, therefore I could use it until I came back home. I am so disappointed in the colors. I actually think I got so upset with it I had a set back
这个答案有帮助吗?
得分 0
1条评论:
Will this work on a 20 fone?anyone tried having an issue similar
完成的
添加一条评论
添加你的答案
calliemoore16 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 5
过去 30 天: 51
总计 21,676
