跳转到主内容
The Lenovo A7 tablet is a 7-inch Android tablet released by Lenovo in April 2015. The A7-30 tablet was released in two versions, the 3G/Wi-Fi model (MediaTek MT8382M) version, and the Wi-Fi only (MediaTek MT8127) version.
Why won't my Lenovo A7-40 power on?
it was fully charged n it just stopped working and wont on
its been 3 days and it wont get on i tried charging it but it wont get charged
回答此问题 我也有这个问题
这是一个好问题吗?
得分 13
3条评论
I have a tablet and it turns on and you can hear everything but you can't see anything
完成的
I have this problem
完成的
my lenovo won t open
完成的
添加一条评论
6个答案
最有帮助的答案
If it does turn on it pops up Reboot and some other stuff too
这个答案有帮助吗?
得分 1
添加一条评论
lenovo tab not turning on
这个答案有帮助吗?
得分 1
添加一条评论
Guys Just press reset button and then press power button..if you cant find the reset button just open the back cover en then you can press it with finger... Good luck
这个答案有帮助吗?
得分 1
添加一条评论
Check the battery. I opened mine and the battery didn´t charge anymore
这个答案有帮助吗?
得分 1
添加一条评论
I had such a problem
The battery just had been moved
I put it right and labeled it
It worked
这个答案有帮助吗?
得分 0
添加一条评论
If you can feel the motor is buzzing, try to check the lcd cable, many lcd cable faulty in this device, that`s my experience, or try to disconnect and put it back. If it`s not charging can be charging port issue or battery even motherboard. try to factory reset with the power button and the volume up button.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
sandy 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 14
总计 3,554
