跳转到主内容
加入维修社区 - 创建账户
Fourth generation of iPad, released November 2, 2012, available in 16, 32, or 64 GB models. Model Number A1458
Ipad 4 doesn't charge
Hello, I installed a new battery and a new lightning port. My iPad turn on, but the battery doesn't charge, when I plugged it to the power outlet, the iPad only indicates "battery charged" when It had only 65% of charge. Only It charges, when my iPad is turn off, but when It turn on, it didn't charge. Now, my iPad doesn't turn on. I changed the battery two times. Also, I re-installed the old lightning port.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 -1
添加一条评论
1个答案
已选择的解决方案
It is very likely that you have damaged the U2 charging logic ic chip, probably happened because you created a short on the main board while trying to replace the battery. It is repairable but it requires a board level repair.
这个答案有帮助吗?
得分 1
1条评论:
do you happen to have a picture of the chip that needs to be replaced
完成的
添加一条评论
添加你的答案
Michael Beltran 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 9
总计 520
