跳转到主内容
加入维修社区 - 创建账户
型号 A1136 / 30, 60, 或 80 GB 硬盘 / 黑色或白色塑料面板
battery replacement
hello! I have check on websites and checking other information. But, I can't not find, when you replace a battery from the IPOD, if you need to replace the LCD screen as well? If I am able to use the same screen when I install a new battery on the IPOD.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 -1
添加一条评论
1个答案
已选择的解决方案
Assuming you are talking about the ipod touch 5th gen then yes you can replace the battery without replacing the screen. Just pull the screen up, unscrew the metal plate and youll have access to the battery. The battery connections are covered by a black cover. just use a pair of tweezers to pull it off. Then just unsolder the battery and put a new one on! its really a lot easier than it sounds
iPod Touch 5th Generation Teardown
I linked iFixit's guide to the tear down. they tore the cable in the video because "we needed to pull off the soldered battery connections before we could tilt the logic board up to peek underneath." Since you don't need to get behind the board you wont need to worry about that. Again just take off the black cover, 3 solder points and youre all set to go!
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
technicianjedi 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 10
总计 198
