跳转到主内容
2013年1月发布。 配备有72倍变焦,全高清摄录。
9 个问题 查看全部
Why is my battery life so short?
Dear iFixit helpers,
I recently purchased a Panasonic HC-V110 for myself and I love everything about it, but I have noticed that the battery life is very short. I'm not sure why this is considering I bought it only two months ago and it hasn't sustained any type of damage whatsoever.
Do I have a defective battery and need to purchase a new one or am I able to fix this problem?
Thanks!
回答此问题 我也有这个问题
这是一个好问题吗?
得分 2
添加一条评论
1个答案
最有帮助的答案
Hey there!
There are two possibilities that I know of for this issue. The first is the temperature of environment. In colder temperatures, the device loses the ability to maintain power. Be sure to keep the device in a room temperature environment to ensure longest possible power life. Are you in a cold enviroment while using the device? The other is that the battery life time is limited. The battery only has a limited amount of life within it. Therefore, if the battery is fully charged and will still not sustain the charge then the battery is most likely worn out and requires replacement.
Hope this helps! :)
这个答案有帮助吗?
得分 1
1条评论:
I'm not sure it's either of those two. I purchased two new batteries with a recent manufacture date and the camera still will not hold a charge. Looked for a firmware update but found nothing. VERY frustrating.
完成的
添加一条评论
添加你的答案
Jenna 将永远感激不已
浏览统计数据:
过去 24 小时: 5
过去 7 天: 7
过去 30 天: 28
总计 333
