跳转到主内容
第四代iPhone。维修过程直观易懂,但前置玻璃和LCD面板无法分开,只能作为同一零件更换。GSM版本, 8, 16, or 32 GB 容量 / 型号 A1332 / 黑色或白色
2375 个问题 查看全部
问题已关闭
Touch screen wont move, even after replacement
I have replaced a display in a iPhone 4, and a couple of weeks later the touch started messing up (not recognising any touch), for small periods of time. Now the iPhone wont budge at all. Have tried several new screen to rule out bad displays.
Could it just be time to call it dead as it is an older phone?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
4条评论
I am currently doing a restore.. Will report back
完成的
Restore did not help.
完成的
hard reset? Also try some compressed air over the connectors and have a real good look if the connectors aren't damaged.
完成的
The LCD connector did slightly indicate some water-damage. It had that white residue (dont know the english word??) around it but nothing was near the digitizer connector. Cleaned it of but no luck.
完成的
添加一条评论
1个答案
已选择的解决方案
Something similar happened to me but I later found out that the phone was exposed to liquid (albeit briefly). Another instance was I somehow broke off a microscopic piece on the logic board. Get a really strong magnifier and look at the logic board to make sure no jumpers,etc.have broken off. If you see something missing/damaged, it'll need to be microsoldered back on. Also look at the digitizer connection on the logic board to make sure any of the pins haven't been bent or broken.
Age of the phone doesn't necessarily doom the phone, just the condition of it.
Good luck and I hope I helped.
这个答案有帮助吗?
得分 0
1条评论:
I could see that the bottom speaker had previously been replaced (it had some sort of stamp on it), but otherwise I was not able to see any other damage to the board. Tried as well as i could to inspect and compare with another board.
完成的
添加一条评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 1
过去 30 天: 1
总计 282
