How to remove shaft bushing on cross brace motor case support
I need to install motor, gear and blade on the right rear cross-brace. When I insert the new pin that secures the new gear and blades I see bushing hole where that pin goes through is egg shaped and allows pin and gear to have to much movement. How do you get that bushing out of the cross-brace motor housing?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
