跳转到主内容
Third generation of iPad, featuring 4G capabilities, released on March 16, 2012. Model number A1430. Repairs require heat and careful prying.
LCD error after front panel replacement
I have successfully replaced the front panel. But now the LCD screen does not seem to work. The led's on the side of the LCD screen light up and the screen turns from black to light blue. It doesn't seem to work.
Have I wrecked my LCD in the process or have I forgot something?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 -1
添加一条评论
2个答案
Check your connectors for the LCD first, make are they are firmly in place. After that do a hard reset by holding the power and home buttons down simultaneously for 10 seconds.
这个答案有帮助吗?
得分 0
添加一条评论
Hard reset as stated above should work you have probably turned the iPad on when the lcd was out so it won't give you an image til you hard restart it
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Mark 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 1
总计 92
