跳转到主内容
Model A1419 / EMC 2806 / Late 2014 or Mid 2015. 3.3 or 3.5 GHz Core i5 or 4.0 GHz Core i7 (ID iMac15,1); EMC 2834 late 2015 / 3.3 or 3.5 GHz Core i5 or 4.0 GHz Core i7 (iMac17,1) All with Retina 5K displays
573 个问题 查看全部
iMac Intel 27" Retina 5K Display Hard Drive Replacement
Since the 1TB fusion drive and 256GB iMac are at same price, if i purchase an iMac with 256 GB SSD, is that possible to insert a HDD myself?
I mean, is the HDD holder will be installed in the iMac with 256GB SSD? and if it is installed, can i build myself a fusion drive with that HDD and the 256GB SSD
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
1个答案
已选择的解决方案
Review this IFIXIT guide: iMac Intel 27" Retina 5K Display Hard Drive Replacement. So you have an idea how much work it will be to add in the HD.
Apple does not supply the needed cable connection for your new drive (see Step 31). You'll need to order it as well as the frame (Step 33).
As this is such a new system you've not likely to find the parts available yet. If you have an Apple authorized service center near you you could try asking them to order them for you.
Now the rub:
Apple uses an internal thermal sensor so the HD drive you get will need to support the newer internal SMART standard. If the drive you want is not compliant you'll need this: OWC In-line Digital Thermal Sensor for Hard Drive Upgrade for 27" iMacs 2012 and Later.
这个答案有帮助吗?
得分 3
添加一条评论
添加你的答案
Steven 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 848
