跳转到主内容
This graphing calculator was originally designed in 1995. The TI-80 has a large screen size 64x48 pixels and 16x8 characters display. Internally it contains a 980 KHz CPU and 7K RAM memory.
问题已关闭
Why is the keyboard malfunctioning?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
The next most common problem with the power would be the physical button being either broke or stuck. In order to repair the button(s) remove the faceplate of the device and make sure there is nothing interfering the motion of the button(s) then reinstall the faceplate and test the problem button(s). If the faceplate has been removed and the inside of the calculator is clean then the next most common solution would be the replacement of the keyboard.
这个答案有帮助吗?
得分 0
添加一条评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 2
总计 73
