Why isn't my tablet turning on?
I pushed the power button and nothing happens.
Hi @randolphmora123,
Does the tablet show that it is charging when you connect the charger to it?
What % of charge is the battery icon showing when you try to charge the battery only and not switch on the tablet?
If it shows that it is charging allow it to fully charge and then try turning it on.
If it still won’t turn on after it is fully charged, can you start and use the tablet with the charger connected and switched on?
If so, then the battery may be faulty and needs to be replaced.
这个答案有帮助吗?
For more information about your XO Tablet please go to the following website: http://xotablet.com/
Also, you can check out the troubleshooting page for this device!
这个答案有帮助吗?
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 7
总计 2,099
4条评论
my USB/charge port is loose. I know why it won't turn on. I need to know how to get it repaired.
由 brobisonus 完成的
y is not truinng on
由 darius matthews 完成的
I push the power button and it doesnt come on.
由 randolphmora123 完成的
Why my vivitar tablet wont turn on
由 Beatricegrace 完成的
