跳转到主内容
Released 2012, model number L610 A point and shoot camera
8 个问题 查看全部
Why do I get a batteries exhausted error?
After using my camera for a period of time, it says battery exhausted on the screen and then turns off.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 33
6条评论
I have the same problem.Bought FOUR new batteries.All have te same response.Grrr.
完成的
i heard you need to use the same batteries as the ones you originally started out with when you got the camera.
完成的
Every time I turn my camera on this happens. I put in fresh batteries and it will work for about 5 minutes and then shut off. However, if I tak ethe batteries out and flip them it will work for a minute or too. My camera has not been dropped or harmed in any way and is just over a year old.
完成的
I sorted mine it needed alkaline batteries as there was no option for zinc batteries in the settings. Dont throw camera do this .4 yrs of crap now solved hurray
完成的
Phillines615 I’m using “Alkaline” and the problem still Exists. I believe that something to do with the battery door. From my research this particular model cool pics L22 seems to have some sort of repetitive problem with the battery door compartment. Because every single battery that it says is exhausted, I have taken out and tested on my multimeter only to find out they are still brand spanking new!! In other words, before I place them in the camera they had a reading of 1.55 and afterwords they were at 1.55. I’m so frustrated I can hardly handle it!! UUUUUGGGGGGG!!!!!!!!!!
完成的
显示更多的1条评论
添加一条评论
25个答案
最有帮助的答案
This error comes from either the camera getting to hot or the batteries being depleted. To relieve this issue let the device sit for a while. If the error persists after letting the device sit, replace the batteries.
Update
Checking the forums this seems to be a common error for this device but there is another reason this may happen. If the battery lid gets loose, the batteries are not held in tight. The extra space causes the batteries to arc which increases the heat inside of the camera. This issue maybe be relived by holding pressure on the side of the camera where the batteries compartment is. This pressure will create the correct contact that is needed for the device to work properly.
这个答案有帮助吗?
得分 6
9条评论:
i have replaced the battery but it shows same error
完成的
With batteries? The main camera batteries or the batteries that you but in the bottom of the camera?
完成的
I took a toothpick and jammed it between the bat and side of bat compartment and pushed it down and then I was able to charge. I believe it was a connection problem. A couple of layers of tape and it should fill the gap when closing the cover. nothing thicker than tape, something thicker may compromise the seal.
完成的
Replace rechargeable batteries with alkaline and error disappears, then inserted back rechargeable batteries
完成的
it is not the batteries or the way the batteries are installed or contact. it is a bad design, may software. chinese made junk @ @
完成的
显示更多的4条评论
添加一条评论
Just read the correct answer, The order in which you plug the charger cable into the charger and then into the camera matters. ( when I read it I couldn't believe the order matters but it does) https://support.nikonusa.com/app/answers...
这个答案有帮助吗?
得分 3
2条评论:
My camera didnt come with a charger cord :/ I can only put batterys in there, but there is a place for the charger.
完成的
This certain camera that it pictures at top and similar ones come with actual batteries, not rechargeable battery cards.
完成的
添加一条评论
charge the battery for 6-8 hours and then you will not have this problem.
这个答案有帮助吗?
得分 1
添加一条评论
It may be because you left it on for a long period of time. Same with me.. I charged my battery for a little over 6 hours and it was fine.
这个答案有帮助吗?
得分 1
添加一条评论
Battery exhausted error occurs due to damage in battery door cap lock.Replace it and the problem is resolved
这个答案有帮助吗?
得分 1
添加一条评论
I have seemed to have solved the problem by using lithium batteries only
这个答案有帮助吗?
得分 1
2条评论:
I bought my Nikon Coolpix P5100
Yesterday. Naturally I charged it
overnight. My question why its say 'Battery is Exhausted". What is the cause and side effect? I'll appreciate if you
answer my questiona and kindly response on my concern. Thank you in advance for your immediately action.
完成的
I do not the reason for the battery exhausted message. The side effect is the camera turns itself off and cannot be used. It makes no sense. All I know is using disposable lithium batteries caused the problem to go away.
完成的
添加一条评论
Mine have the same problem. Im doing only 1 solution everytime the problem occurs.
1. Remove the battery for 5-10secs then put it back in.
2.Unplug the usb cord on the charger.
3. Then insert again the cord into the charger
4. Put the charger on the wall socket
5. Connect the charger in your camera
Then suddenly the charging indication light will appear :)
You just have to be patient everytime it fails, just keep on doing it several times.
I guarantee it will work and it will saves your money ;) DO NOT STOP UNTIL THE CHARGING LIGHT APPEARS. Goodluck!
Remember: PATIENCE IS A VIRTUE :)
这个答案有帮助吗?
得分 1
2条评论:
Thank you Celine. Tried this and it worked. :)
完成的
I have a Nikon l24 and it says battery exhausted
完成的
添加一条评论
NO NO NO NO NO...
To solve the "Batter Exhausted" problem, first open the battery compartment and check what type of battery you are using - Alkaline, Lithium etc.
Next switch on the camera and press menu button and then tools option (wrench).
In the list, find the "Battery Type". You should see some options:
Alkaline,
COOL PIX (Ni-MH)
Lithium
Select one of the above options corresponding to the type of battery you are using.
That should solve the problem.
这个答案有帮助吗?
得分 1
2条评论:
The thing is, whenever I turn on my camera its gives me the error and just shuts off in 15 seconds.
完成的
The battery type is the first thing to check. Especially if the camera shows suspicious value at battery level.
完成的
添加一条评论
My wife had this problem which annoyed her so much that she stopped using it. I investigated and found out that in the battery settings there was no mode for standard zing batteries . I purchased some alkaline batteries and set mode to alkaline and they presto . She didnt use the camera for 7 years because of this lol. A simple thing that made a world of difference try before you do anything else .BATTERY
这个答案有帮助吗?
得分 1
1条评论:
Nothing to do with battery cover or charger or how made .it has no setting for zinc battery.if you still having trouble I'll have your cameras lol and I'll put some alkaline batteries in. Problem solved
完成的
添加一条评论
I had this problem also. I read that if you charge the battery IN the camera it might cause this problem. I purchased a wall charger to charge my battery and I haven't had this problem since. It probably would help to get a new battery if yours is old. Overheating can cause the problem also. Good luck.
这个答案有帮助吗?
得分 0
添加一条评论
The battery needs to be charged by using an external source, such as attaching the usb charging cord to your laptop. You can also take the battery out and charge it by itself, by placing it in the included battery wall charger.
这个答案有帮助吗?
得分 0
添加一条评论
Got the same problem with COOLPIX S2600. Solved the problem by charging the camera with the memory (SD) card removed. Advice: Do not use your camera when the battery is drained.
这个答案有帮助吗?
得分 0
添加一条评论
Use lithium batteries. I do not get the battery exhaust message when using lithium batteries.
这个答案有帮助吗?
得分 0
4条评论:
What do you mean by lithium batteries?? Which model no. of lithium battery you are using now to resolve the battery exhaust problem? Because I am having the same problem using lithium ion battery EN-EL23.
完成的
I am just using Energizer AA advanced lithium batteries. Haven't had the "exhausted battery" message since.
完成的
.it has been three months with a regularly used camera it has yet to die, or give me the exhausted battery error since I put in the disposable lithium batteries
完成的
Use alkaline no problem
完成的
添加一条评论
Had the same problem charged it for 8 hours still nothing then I plugged the charging cable into my Samsung phone charger plug and work straight away
这个答案有帮助吗?
得分 0
2条评论:
Just want a workimg camera!
完成的
Alkaline batteries
完成的
添加一条评论
This only happens to me when I am used the video mode. I NEVER use rechargeable batteries, and the new batteries have the same problem. My guess is bad software or bad battery door. Door is a very cheap design.
这个答案有帮助吗?
得分 0
2条评论:
Not bad software use alkaline batteries
完成的
. . . . because the batteries WERE low. Old batteries , too long in the HOT garage and my "battery checker" was lying to me about the battery's charge. Use voltmeter to get a true state of new or used batteries.
完成的
添加一条评论
I overcame the problem by replacing Nikon recharger and connecting charger cable. Nikon lithium battery now charges perfectly.
这个答案有帮助吗?
得分 0
1条评论:
I had the same problem, but since I changed the settings to alkaline batteries and used Panasonic alkaline batteries it's working great...
完成的
添加一条评论
Read this on Tom's guide.
''try this ... i had the same problem with the same camera and this fixed it.
remove the battery, and remove the memory card ... then re-install the battery & turn on the camera.
this process seems to reset the camera, if the battery ran too low.
now you can re-install the memory card & battery and resume normal operation.
be sure to check for the small flashing green light on the back of the camera (next to the "flash" indicator symbol). it should be blinking when the camera is charging.''
Actual Nikon fix
这个答案有帮助吗?
得分 0
添加一条评论
I just bought a new battery for coolpix digital Nikon camera 12, but after taking 20 picture , Battery is always exhauted. I am appreciated if you anser my question
这个答案有帮助吗?
得分 0
1条评论:
Need alkaline batteries and settings to this mode
完成的
添加一条评论
I had the same problem with my Coolpix camera: I could charge for a couple min, but then the light went to “fast blink” mode and stopped charging and “Battery Exhausted” mode. I thought it might be a bad battery…but.. WITH TWO DIFFERENT BATTERIES? That made no sense. I read through many on-line answers, none worked for me.
What worked for me was simply using a different transformer. The transformer I’d been using (apple white transformer) was too small: 5 V/2.1 amps (about 10 W) It would change the camera and then stop, and the light began fast blinking. I replaced it with a larger transformer : 5V/3.1A (about 15 W) and that worked fine. Problem solved. It was just that simple.
这个答案有帮助吗?
得分 0
添加一条评论
I solved the problem by using alkaline batteries -Duracell brand. It wss driving me crazy -I kept getting the exhausted batteries sign and couldn't take photod, unless I replaced them every day or so. THE PROBLEM IS THE TYPE OF BATTERIES.
Use alkaline ones. It's worked for me.
这个答案有帮助吗?
得分 0
添加一条评论
I had the battery exhausted error message when I tried to recharge my coolpix S7000
I found using the supplied plug and cable resulted in the battery being depleted.
i tried a different usb cable plugged into an Anker multi point charger worked
hope this helps
这个答案有帮助吗?
得分 0
添加一条评论
Thanks very much. That’s what I ended up doing too. It was a simple solution: ALKALINE batteries only!
这个答案有帮助吗?
得分 0
添加一条评论
Who DOESN’T use Alkaline batteries??? LOL…
I’m using Alkaline batteries, and still same issue.
这个答案有帮助吗?
得分 0
添加一条评论
if you look on battery label it says 3.0 to 2.4 dc v b1.4 to 1.9 a if you test battery with multi meter and your battery is 1.55 and other is 1.55 add both together your over by .10 so make sure battery voltage says 1.2 v on battery that way you should be in 2.4 v to 3 v top and if that don't work in many cameras there is a small battery that powers display time memory and charge might need to be replace c heck online youtube you will see what i mean
这个答案有帮助吗?
得分 0
添加一条评论
لماذا بطاريه الكاميرا لا تعمل
Translation
Why is the camera battery not working?
这个答案有帮助吗?
得分 0
1条评论:
@tcxeus9dkbu0xq3 what make and model camera? What type of battery are you using
Translation
ما هو صنع وطراز الكاميرا؟ ما نوع البطارية التي تستخدمها
完成的
添加一条评论
添加你的答案
Jeremy 将永远感激不已
浏览统计数据:
过去 24 小时: 15
过去 7 天: 147
过去 30 天: 569
总计 105,249
