跳转到主内容
Model A1224 / Mid 2007 and Early 2008 / 2, 2.4, or 2.66 GHz Core 2 Duo processor
How to replace the hard drive?
I need to replace my hard drive on my iMac 20-inch (Mid 2007) Model Number: A1224.
I was looking at nothing big cause its my secondary mac which is mainly used for interest browsing. So I was going with a 500GB,
Okay Three questions. Whats the difference with these two hard drives (below). Would either work properly with my model? And is it really worth double for the hybrid model for my needs?
> Hybrid Hard Drive 3.5-inch SATA
Type: 3.5" Serial ATA-600
Spindle Speed: 7200 RPM
Type: 3.5" SATA
Interface Type: Serial ATA
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 -1
添加一条评论
1个答案
已选择的解决方案
The only difference you have here is a standard HD vs a SSHD (hybrid drive). Both are 3.5" and you list one as SATA and the second one SATA III (6.0 Gb/s) [aka: Serial ATA-600].
What you didn't tell us was the make and model of the drives to be able to tell you more.
In your case your system is only able to support a SATA II (3.0 Gb/s) drive.
So your SATA III drive won't work unless it offers a jumper to alter its SATA I/O speed to SATA II or SATA I (1.5 Gb/s).
I do recommend hybrid drives when ever possible over standard HD's as the deeper cache they offer adds a lot of zip booting up and running apps. You may want to checkout a Seagate desktop SSHD drives as they offer auto SATA port detection so it will work in your system without any problems.
这个答案有帮助吗?
得分 3
2条评论:
okay thanks for the suggestion. so if i were to purchase the
Seagate 1TB Desktop SSHD SATA 6Gb/s 64MB Cache 3.5-Inch Internal Bare Drive (ST1000DX001). it would run good with my imac.
完成的
Yes, the Seagate ST1000DX001 series SSHD is what you want. Follow this IFIXIT guide to put it in: iMac Intel 20" EMC 2133 and 2210 Hard Drive Replacement.
完成的
添加一条评论
添加你的答案
matt 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 6
总计 438
