跳转到主内容
The fifth Google Nexus phone. Officially announced on October 31, 2013, it sports a 4.95" 1080p display, a 2.26 GHz Snapdragon processor, and LTE support. Powered by Android 4.4.2, KITKAT. Manufactured by LG.
222 个问题 查看全部
Bootlooping because of power button
There's a common issue with N5 where the power button causes the phone to bootloop. I've stripped it down, but I'm unsure what to do with regards to fixing this issue. I've been quoted £30 to fix the power button, but I'm not sure if this will fix the issue.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 11
添加一条评论
3个答案
最有帮助的答案
The problem is with the physical button on the motherboard, which is just not so well designed, because dirt can get stuck into it.
Remove the motherboard from the unit, and blast some rubbing alcohol into the actual button part with an air duster. Wait until the board is entirely dry and reassemble. I have to do this every couple of months, it's a bit of a drag.
这个答案有帮助吗?
得分 2
添加一条评论
I temporarily fixed mine by button bashing the power button until the phone rebooted. I felt pretty stupid doing so but after about 20 seconds of really fast clicking on it quite hard it worked. I already tried replacing the battery twice since boot loops are often caused by power issues but without result. Anyone know a solid fix? Is it the button on the logic board that has to be resoldered?
这个答案有帮助吗?
得分 1
1条评论:
I have the very same problem. I really don't know what to do.
完成的
添加一条评论
Saskia's answer above is the best solution short of replacing the part (i.e., replacing the motherboard, in most cases probably more hassle/expense than it is worth).
One quick and dirty, no-disassembly trick that worked for me several times was to rap the phone (in a bumper case) sharply against the edge of a counter with the power button facing down). Optional followup: with the button still facing down use the crevice tool (with the case off) in hopes it would catch anything that had worked lose in the thin gap between the switch and the phone body.
Not ideal but handy if you are on the road and want to give it a try.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Liam Cooper 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 3
过去 30 天: 13
总计 3,333
