跳转到主内容
任天堂 3DS 的升级版。它拥有更大的屏幕、更长的电池续航时间、更高的像素密度和更好的设计。
Why won't the battery charge
My 3ds Xl will not charge. The charging light comes on but the battery does not charge. I have checked the fuses and they are good.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
2条评论
I have got the same problem,but the charging does not turn on.
完成的
i have the same problem, i have a normal 3ds and even the charging stand won't work
完成的
添加一条评论
2个答案
最有帮助的答案
First try a new adapter . My son had 2 Adapters that went bad and this same issue happened. Next i would replace the battery. If this doesn't solve the issue then your looking at a problem with the charging circuit.
这个答案有帮助吗?
得分 1
1条评论:
Yea. This is what I figured. I can put the battery in another 3DS (using the same adapter) and charge it and then it works until the battery dies.
Trying to find the fault in the charging circuit. Thanks
完成的
添加一条评论
For my problem are the same also,, it only can play while in AC but not in battery .
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Mental 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 1
总计 4,279
