跳转到主内容
1.8GHz dual-core Intel Core i5 (Turbo Boost up to 2.8GHz) with 3MB shared L3 cache
371 个问题 查看全部
No Audio Input/Output Devices detected!
Hi All,
My Mac was functioning wonderful until, I upgraded to yosemite suddenly the audio input/output devices aren't detected! I have tried all the trouble shooting steps online NVRAM, PRAM to clean install of the software back to mountain lion and now running mavericks, but all in vain!
Took it to the authorized service centre they failed to diagnise my problem and detected fault on MLB (Main Logic Board) for which they are charging a bomb!
I would like to know if there is any work around to get the sound working! I read about external audio devices which doesn't require any drivers come in handy (Sabrent) should I settle for this? I am confused and frustrated with my MacBook Pro! Please HELP!
TIA
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 3
2条评论
Just so its clear here your built-in microphone and speakers are not working, correct? or are you having problems with the audio output phono jack?
完成的
i am suffering with the same problem, the same model, and also dont find any solution for it.
Any solution out there?
完成的
添加一条评论
1个答案
已选择的解决方案
Have you looked at these? USB audio input/output adapters
这个答案有帮助吗?
得分 3
添加一条评论
添加你的答案
xroadsinc 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 6
过去 30 天: 13
总计 2,974
