跳转到主内容
The iRobot Roomba 655 Pet Series vacuum manufactured in 2012. Costco exclusive.
27 个问题 查看全部
Why will my Roomba not charge?
I placed my Roomba on the charging station and left it there overnight. The next morning I tried to run the Roomba through a cleaning cycle, and it gave a low battery signal.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 15
22条评论
where can I find replacement parts, such as lint trap etc.
完成的
pls reply asap
完成的
Roomba website has all the parts. You may pay by paypal.
完成的
My Roomba does not dock or charge either it's clean and 3 months old!! I'm mad I paid $500. For the darn thing!!
完成的
That is what mine is doing I paid 700 for mine! Did you get it to work again?
完成的
显示更多的17条评论
添加一条评论
6个答案
已选择的解决方案
The contact points on the Roomba may be dirty. Roomba's charging contacts are under the front bumper of the robot. This means that they are in front of the brushes, and see a lot of debris. They can easily get dirty and increase the resistance in the charging circuit.
If after cleaning the contacts, the Roomba will still not charge correctly, you may need to replace the battery or get a new charging dock.
这个答案有帮助吗?
得分 17
17条评论:
I've clean contacts on both the roomba and dock. It has a new battery (only used once since install). Dock is working. Any other suggestions would be appreciated.
完成的
I have the same issue. New battery, dock has green lights, but Roomba is still flashing red after several days in the dock. Everything is clean on the Roomba and the dock.
完成的
Cleaned the contact points, worked like a charm thanks! :)
完成的
Tried cleaning the metal connectors. Did NOT work. Any other suggestions
完成的
显示更多的12条评论
添加一条评论
You have to clean the contacts on the dock and the Roomba. Try using something abrasive like a Brillo pad. Like this:
https://m.youtube.com/watch?v=ItVt8RM6BB...
这个答案有帮助吗?
得分 6
7条评论:
Check the contacts on the charger. They are essentially spring loaded steel so they will push up and make contact when the Roomba is docked. I had one that was stuck down so wouldn't make contact.
完成的
I checked the dock with a voltmeter to make sure it was not the dock. Although the contacts all looked shiny and clean, I went over everything with an eraser and followed up with alcohol. Still no luck. Finally broke out the steel wool on the roomba contacts and it's working like a champ. Thanks Tarek!
完成的
Lightly scrubbing with steel wool did the trick for me!
完成的
Here's a great DIY fix for a Roomba that won't charge.
完成的
Should the charging light (orange flashing battery on 880 model) come on even if the contacts are dirty or not connecting? They look clean to me.
完成的
显示更多的2条评论
添加一条评论
I have to stick something like a coaster under the back of mine so it will charge. All points are clean & battery is fine. It just won't align properly.
这个答案有帮助吗?
得分 1
2条评论:
same here, have to prop up rear of roomba to get it to charge.
完成的
try cleaning dust from under the wheel
完成的
添加一条评论
It could also be an error with the hardware and the triggering of the pads below the roomba. A great forum thread about fixing it can be found here:
http://www.robotreviews.com/chat/viewtop...
这个答案有帮助吗?
得分 0
1条评论:
New to this today. After difficulty docking, finally moved station, but nothing happening although it says charging. Does nothing flash while charging Never seen anything but blue when it tried to go home and white. Just sitting there .. not sure it is charging
完成的
添加一条评论
Try on a hardwood floor. Mine was not charging on carpet but when moved to hardwood / like new.
这个答案有帮助吗?
得分 0
2条评论:
Do the roomba can connect to app?
完成的
Model Roomba 655
完成的
添加一条评论
There are a few reasons why your Roomba might not be charging.
One possibility is that the charging cable is not properly inserted into the charging port on the robot. Another possibility is that the battery is damaged or the charging port on the robot is defective.
If you think the problem might be the charging cable, try using a different charging cable to see if that solves the issue. If you think the problem might be the battery, you can try replacing Battery.
If you are still having trouble getting your Roomba to charge, then contact with irobot or explore more about this issue from here
https://homespoiler.com/roomba-not-charg...
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Rhett 将永远感激不已
浏览统计数据:
过去 24 小时: 10
过去 7 天: 31
过去 30 天: 164
总计 231,843
