跳转到主内容
Samsung's 5th-generation Android-based Galaxy smartphone was released April 11, 2014. Improvements to the phone include a fingerprint scanner, updated camera, larger display, and water resistance. It is available in four different colors; black, blue, white, and copper.
577 个问题 查看全部
USB Port cover broke off, fix?
The waterproof(?) cover of the USB charging port has broken off. Can this be fixed/replaced without sending it in?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
2个答案
最有帮助的答案
Yes you can replace this without sending it back for replacement.
This part is held in place with one screw inside the battery cover by the USB port.
Unscrew that and lift up the plastic that holds the cover in place, do the reverse to put it all back again.
这个答案有帮助吗?
得分 2
添加一条评论
replace it, you can buy the part on ebay for a few dollars.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
roberthovey 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 2
总计 791
