跳转到主内容
The Wintec Filemate Clear is an Android tablet with a 7 inch screen and 1.2 GHz processor. The tablet features 2 cameras, 2 megapixel rear camera and a VGA front facing camera.
Why wont my device turn on?
Device will not power on after using the power button.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 4
1条评论:
The battery may be dead try charging the tablet. If this does not work then try holding the power button down for 5 seconds and your device should restart and turn on. If neither of these options work work then you may have a faulty charging pin or a faulty battery.
完成的
添加一条评论
2个答案
Typically, the is an issue with the battery. Try turning on the device while it is charging. If this doesn't work, this means that your charging pin is faulty and is preventing the battery from receiving charge. If it does turn on while charging, this means that the battery is dead and needs to be replaced.
这个答案有帮助吗?
得分 0
1条评论:
How do I change my betters in My tablet? Please let me know how.
完成的
添加一条评论
This tablet is brand new.  Gave to granddaughter for birthday and it is dead.  What can I do to get one that works.
这个答案有帮助吗?
得分 0
1条评论:
Tried plugging in and nothing. Also took to a computer tech and he said it was dead.
完成的
添加一条评论
添加你的答案
Akiyah 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 8
总计 895
