跳转到主内容
Part Number: DD11210 The TotalPond pump, which was designed for water gardening enthusiasts, circulates 210 gallons of water per hour, maintaining the ecological balance of small ponds. It is used in water garden less than 3 feet by 6 feet ponds and waterfalls to provide streams of water up to 7.8 feet high.
2 个问题 查看全部
问题已关闭
How do I get my pump to stop making bubbles?
My pump works but it makes bubbles.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
This is most likely due to a broken impeller, and the impeller assembly will need to be replaced. It could also be due to air locked in the pump housing, which is most likely due to the pump not be fully submersed.
这个答案有帮助吗?
得分 0
添加一条评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 6
过去 30 天: 8
总计 638
