跳转到主内容
Part Number: DD11210 The TotalPond pump, which was designed for water gardening enthusiasts, circulates 210 gallons of water per hour, maintaining the ecological balance of small ponds. It is used in water garden less than 3 feet by 6 feet ponds and waterfalls to provide streams of water up to 7.8 feet high.
2 个问题 查看全部
问题已关闭
Why is my pump making a strange noise?
I have a pond pump that started making a high pitch noise. Any suggestions on how to make it stop?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
The noise is most likely an indication that the motor has failed. It will need to be replaced, along with the impeller assembly.
这个答案有帮助吗?
得分 0
添加一条评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 4
过去 30 天: 4
总计 441
