跳转到主内容
My iPod shuffle is not starting
My iPod shuffle 1st generation 1GB capacity is not starting, just showing starting on the screen and do not process onward.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 3
添加一条评论
1个答案
已选择的解决方案
What light pattern does the iPod show ?
since resetting isn't more than switching the shuffle off and after 5 seconds on - i won't get deeper into that point. maybe you should restore it with itunes. it's always problematic to tell something on a device that isn't capable of showing anything more than a light pattern. ah and by the way - the colored texts are links, you can click on them
这个答案有帮助吗?
得分 1
2条评论:
When I found a download, an iPod Reset Utility, my MacBook Pro told me not to open it...that it might contain Malware. Any ideas? The back shows green, but when I press the button on the front, there is no sound. There is a thin rectangular push-in just under the green section, with a battery icon next to it.
I've tried to recharge it overnight on my computer. Nothing. Then using the USB port into an Apple adapter into electricity. Again. Nothing. Ideas?
Ideas?
完成的
i have the same issue except it has only 1 solid green light
完成的
添加一条评论
添加你的答案
abid 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 7
总计 3,274
