跳转到主内容
Nokia Lumia 920由诺基亚开发并于2012年11月发布,搭载Windows Phone 8操作系统。
Flickering screen when starting the smartphone
Flickering screen when starting the smartphone, then the screen goes off. Apparently smartphone presents normal operation although the screen does not turn more after starting the system.
Changing the Motherboard Flex Cable Ribbon I fix this?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 -1
添加一条评论
1个答案
最有帮助的答案
Your problem was caused by damaged LCD screen, not the motherboard flex ribbon. Replace a new LCD screen can solve it. The tutorial guide is here: Disassembling Nokia Lumia 920 and the part is here: http://www.etradesupply.com/oem-nokia-lu... Good luck.
这个答案有帮助吗?
得分 1
2条评论:
Ok Mia, thanks very much. I will try here and give a feedback.
完成的
Today I replace a new LCD screen and the problem persists...
完成的
添加一条评论
添加你的答案
vinnywebmaster 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 1
总计 408
