跳转到主内容
App-enhanced Dual Alarm Stereo Clock Radio for your iPhone/iPod/iPad released March 2012 (Model #iD95BZC)
Time display unreadable as it is missing several characters
Clock display is unreadable. Calendar info at the bottom of the screen is ok.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 15
5条评论
Does anyone have a fix for this issue? I'm using mine with my newer phone and the clock display is the only issue I'm having.
完成的
model iD91 display disappeared for 2 years, until I discovered it did this when the room was not cold. In a cold room the display is perfect. Called ihome who gave me the same basic instructions which does not work. Anyone else solve this strange problem?
完成的
Yes i do. It doesn’t work. Hasnt for years. Its junk.
完成的
Hi to everyone around here. I have an iHome ID95 with the same defect. Since I love it because of its sound quality and features I was not going to give up with the task of fixing it. From the datasheet of the IC that drives the LCD display (MB95F378E), I found that is is possible to supply it from 1.8 to 3.6 VCC. I thought that since the LCD starts to fade out when temperature rises above 25 °C, and it is very common in most houses, it should be the LCD drivers circuit that isn't able to continually source the needed signal. So I tryed to overdrive the IC. To do so, I used an external power supply and started with the 3.3 VDC that is the same VCC that provides the internal regulator. With the fault at view and rising the external power supply slowly, the LCD starts to show normal again. I found out that at the maximum VCC that is rated for the IC, it wasn't the best value for the LCD to show as a brand new unit does. So I decided to go on and arrived to 4.2 VDC.
(Cont.)
完成的
(cont.) The circuit still worked and let it going at the 4.2 VDC for a whole day to verify that it wasn't just a lucky shoot. Well, finally I build a "parallel regulator" based on a 78L05, wich takes the power in from a 6.5 VDC that I found internally in the ID95, and to get the needed 4.2 VDC to feed the MB95F378E, I just conected a NPN transistos in series with the 78L05 out terminal as a diode to produce a ~0.8 VDC drop from the 5 volts. I used the EB juncture because it has a variable drop value from aprox 0.7 volt with low current up to 1.2 volts drop with 300 mA. This work was made on 17/03/2019 so it has more than a year working. Any one who has an unusable ID95, can try this mod to get it back to fully operational state. I have a couple of pictures that I toke but I really don't know how to upload them to this site. So this is the link to a folder with all the needed info:
https://mega.nz/folder/REkFzJiI#iSAxRsNn...
I hope it is of help to somebody that loves iHome as I do. Regards.
完成的
添加一条评论
7个答案
已选择的解决方案
I had the same problem! My model is iDL43 and it is only 2 months old. I just fixed the problem!! I called the iHome Audio people (I-800-288-2792) - You may want to call because there may be different instructions for different models but this is what they told me to do:
1. Unplug clock/radio
2. Take batteries out of bottom of radio (unscrew and remove batteries, you may not have realized there were batteries!)
3. Wait 20-25 minutes for clock/radio to 'reset'
4. Plug clock/radio back in
5. Viola!! IT WORKS!
6. The woman at iHome Audio said if it works then you can put batteries back in, if it doesn't work call them back. I am not putting the same batteries in, they are an unknown brand, maybe old(?) or cheap.
这个答案有帮助吗?
得分 8
20条评论:
So simple and it worked.
完成的
same problem here, screen has gone bad in 2 years after purchase. POS
完成的
Same problem Here, unfortunately product is out of warranty.
This appears to be a manufacturing defect which does not rear its ugly head until the clock has been in operation for more than a year. I bought the radio clock primarily as a clock, and now I cannot tell time on it....
完成的
Same here screen display stop working after two years of service.
Could it be that were on to something that this product is defective from manufacture
完成的
Same here. Also within 2 years of purchase. I have never had a cheap clock/radio exhibit such an issue.
I have emailed iHome, but as it is out of warranty, well....
Looking closely at the Yamaha TSX-B72, as I doubt I can trust iHome after this. In addition, I want AM reception as well as FM, and all their new products are FM only.
完成的
显示更多的15条评论
添加一条评论
I have the same problem that the Clock display segments started to fail after about one and a half years. No answer from iHome on this. I can't afford to buy a new clock radio every year, looking for a solution from other companies.
这个答案有帮助吗?
得分 1
1条评论:
See my solution on the other post. Regards.
完成的
添加一条评论
I have this same problem with the iBT97. Once a year or so ago, this came up and the unplugging everything solution worked. This time it is not working. I unplugged it and took the battery out and left it that way for a whole day. When I plugged it back in, the display is almost unreadable.
Anyone figured out a more involved fix? Replace the display or a board?
这个答案有帮助吗?
得分 1
1条评论:
No its junk.
完成的
添加一条评论
iHome told me that the displays weren’t meant to be repaired. So they offered me a 40% discount on a new product but I decided to pass and look for a better quality product elsewhere. No more iHome junk!
这个答案有帮助吗?
得分 1
3条评论:
I have an inbox glow and the stations don’t light up on fm
完成的
Junk. Ihome should have recalled the fkg clocks. I have two. They stopped working in two years. Unreadable. Junk. What do they care a reputable company would have recalled them. But. China made junk is a chinamans dream. American dummies keep buying it over and over. I will never buy ihome anything. Ever. I likes my old clock radio. Emerson. Made in the usa. Its 30 years old. Not pretty to look at or modern. Doesn’t charge anything but i can tell time!!! Shame on this company and the companies that support such junk. Big tech. They only care about themselves. I miss American made.
完成的
We must do our best to BOYCOTT COMMUNIST CHINA!!!
完成的
添加一条评论
I have the idl45.. same thing started happening. To be fair I did get this 12 years ago, everything else still works fine but now the clock is failing. I looked for a solution all over the internet. Generally speaking these are not repairable unless you have advanced microcircuitry repair skills. Salvador Sanzone apparently repaired his by wiring additional 4.2 volts to the LED driver by soldering specific spots and reducing with a resistor.
For the rest of us the only option would be to replace the display of the clock. I've taken apart the idl45 and the clock display is on its own circuit board and attaches to the main board with a cable. It would be fairly easy to replace with a couple of screwdrivers(and a bunch of screws). But I'm not willing to put too much money into this as the only way to get another working clock would be to buy another used ihome clock and take its display. The replacement clock would also be well over 10 years old as well and could fail at anytime. Kind of sad since my parents have clocks from the 90s that still work just fine.
这个答案有帮助吗?
得分 1
添加一条评论
Mine is going out also after about one and a half years. This was not an inexpensive item to fail this soon!!! No more digital iPhone items for me!
这个答案有帮助吗?
得分 0
添加一条评论
My iDL45 is doing the same thing, took the battery out, unplugged it for 30min. put it back together and display was better, but did not last long, now the battery is dead, have to get a new one. I wonder if it could be a cold solder joint, failed capacitor? anyone know?
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
JIM 将永远感激不已
浏览统计数据:
过去 24 小时: 10
过去 7 天: 54
过去 30 天: 193
总计 58,007
