跳转到主内容
A portable e-book reader developed by Amazon. Repair is straightforward and requires only prying tools and screwdrivers.
Can the USB socket be replaced without replacing the motherboard?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 7
2条评论
This is for the kindle paperwhite.
完成的
I can’t recharge the battery .The yellowflashes intermittentantly as I wobble the recharging cord seemingly there is a connection problem.
What do I have to do to restore the charging capacity.?
Have tried several recharger cords.
Your advice would be welcome.
Thankyou
Mairin Campbell
完成的
添加一条评论
1个答案
已选择的解决方案
The USB socket is soldered to the motherboard, so it can not be easily replaced without replacing the motherboard. In theory the socket could be replaced with some careful soldering work if you could get your hands on a replacement socket. For someone experienced with replacing small components on circuit boards I'm sure it would be possible, but if you are a beginner with this sort of thing you may do more damage to the circuit board by overheating it. Look closely at the photos in this guide before deciding to try this repair.
这个答案有帮助吗?
得分 8
添加一条评论
添加你的答案
Tom 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 13
总计 1,876
