跳转到主内容
Repair and disassembly guides for the HP Color LaserJet 2700n printer.
Why doesn't the display work?
Hello,
The display of my HP LaserJet 2700 don't work.
Only the backlighting and the LED are working.
Thanks in advance for your help.
Best regards
David
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
If the display went from good clarity to no clarity, its not the display itself. Check the Dimm chip in the Formattor, or change out the Formattor. You can also do an engine test which will tell if your DC Controller board is okay. Sometimes known as a line test, most laser printer will have a tiny hole on the side of the printer that can be pushed in with a pencils tip.
这个答案有帮助吗?
得分 0
添加一条评论
Your low voltage power supply might be bad - Let me know if you need a part number, HP laser printer parts can be found on line.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
David 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 2
总计 312
