跳转到主内容
A guitar shaped controller for Guitar Hero III of the Guitar Hero video game franchise.
29 个问题 查看全部
Broken Connection - blinking lights
Hi Fellas,
up to now my Guitar worked fine. Just today as I tried to connect it seems to connect as Controller No. 2 but the other lights keep flashing and nothing works.
USB connector is unlikely because my other Guitar connects fine and the Broken one doesn't work with my Second connector as well. So I assume the Receiver of the Guitar.
My Problem is now I found no hint where to look for the Receiver Inside the Guitar. Do you have any Info for me about that?
Thx in Advance.
Bye,
Ferdinand
回答此问题 我也有这个问题
这是一个好问题吗?
得分 6
添加一条评论
5个答案
最有帮助的答案
I had the same issue. Controller used to work fine, but after a few years I discovered it wouldn't synch. I tried my other guitar with the USB dongle and that synced, so I knew it was the guitar. I replaced the 220uF @10v capacitor on the main circuit board and it fixed the problem.
Probably a good idea to also replace the 47uF @10v too, since the factory components are poor quality.
这个答案有帮助吗?
得分 3
4条评论:
I replaced the capacitor and the problem persists. Any ideas?
完成的
The 220uF capacitor change worked for me. Previously, the LEDs blinked in sequence but never synced to the dongle, but now fixed once capacitor was replaced. Thanks.
完成的
It's the correct fix done a few with same issue.. If it's not worked check soldering or polarity or replacement capacitors...
完成的
Great! Just replacing the 220 one did the job here! Thanks!
完成的
添加一条评论
Worked for me: http://www.fixya.com/support/t1232769-it...
这个答案有帮助吗?
得分 1
添加一条评论
Hey Ferdinand,
i got the exact same problem.
Do you have any new information or solutions?
Regards,
Henning
这个答案有帮助吗?
得分 0
添加一条评论
i’m having this problem where it flickers irregularly. it’s happening on 2 guitars, 2 sets of batteries, both when the receiver is connected directly to the PS3 as well as PC (no hubs). sadly, i don’t know where my other receiver is.
here’s what it looks like: Guitar Hero 3 controller glitching / random flickering - YouTube
any idea the likelihood of it being the receiver?
这个答案有帮助吗?
得分 0
1条评论:
More than likely be capacitors in the guitars they are known to fail giving the exact symptom you describe
完成的
添加一条评论
Capacitors on the les paul gibson model suck jus got one the other day and has this syncing problem what makes this even worse are the screws #0 square like are we serious 🤣
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Gardovan 将永远感激不已
浏览统计数据:
过去 24 小时: 5
过去 7 天: 61
过去 30 天: 290
总计 39,384
