跳转到主内容
加入维修社区 - 创建账户
7.9 inch display / Model A1432 / Available in black or white / Announced October 23rd, 2012 / 16, 32, or 64 GB capacity
LCD - Backlight missing some illumination
Just replaced the digitizer and on re-assembly I've noticed the bottom edge of my ipad has four dark patches. Looks like some of the backlighting LED's are not working? Could it be a single damaged filter connecting the LCD connector? Looks like there are 6 LED drive connections off the connector, so just wondering if I have blown a filter?
Cheers,
Matt
回答此问题 我也有这个问题
这是一个好问题吗?
得分 -1
5条评论:
Matt, Can you post a picture.
完成的
Any ideas guys??
完成的
help?? Please..
完成的
Hey Matt--looks like you solved this, congratulations! You want to update this question to show us which component was damaged?
完成的
添加一条评论
1个答案
I guess the only way to really know is too try a different LCD. The LCDs are pretty fragile. Could also be connector damage, but try a different LCD first then go from there.
这个答案有帮助吗?
得分 0
2条评论:
It was the filter - one of the 6 was o/c, therefore losing a string of Led's.
完成的
http://www.cyberdocllc.com/wp-content/up... Replaced one of the 6 filters (labelled as Resistors) as shown on this photo in the green box. These 6 Filters connect to the LED Strings in the LCD, so if one goes down you lose a whole string! :-)
完成的
添加一条评论
添加你的答案
matt74 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 16
总计 191
