跳转到主内容
Released in May of 2013, the Xperia L is an Android smartphone featuring a 4.3" screen, 8 MP camera, and a dual-core processor. Identified by model numbers C2104 and C2105.
20 个问题 查看全部
wi-fi is not working. how to repair it?
wi-fi is not working. how to repair it ?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 7
添加一条评论
3个答案
最有帮助的答案
First of all tell me if issue is the same booting your xperia in safe mode
Turn off the device.
Press and hold down the power key until the phone vibrates.
Wait until the Xperia™ logotype disappears.
Press and hold the volume down key. The device then restarts in safe mode.
To exit safe mode, restart the device.
So if your phone works fine in safe mode probably issue is caused by
- a conflict with a third party app that you installed after purchase
- firmware corrupted
So first of all you can remove all recent third party apps and if issue persists make a factory reset.
Remember that with reset you will loose all your datas.
for more information, https://talk.sonymobile.com/t5/Xperia-L/...
这个答案有帮助吗?
得分 2
1条评论:
I did all above steps and still the issue persists, I also tried by repair software option through PC companion.
完成的
添加一条评论
the phone has wifi problem that is activated each time the phone is turned off and turned on automatically
这个答案有帮助吗?
得分 0
3条评论:
did you get solution
完成的
the same problem is happening with me please tell any solution
完成的
this problem not solving with software repair, this killing me. Please solve it
完成的
添加一条评论
Even I'm facing the same issue. when I switch on wifi..... Phone hangs and start keep on rebooting.
When I visited Sony service , they said it's the motherboard compliant.
This is what I got answer from Sony service center.
Bloody Chinese Mother f-ckers.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
ahmedsaleh1985 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 2
过去 30 天: 5
总计 7,804
