running slow even after formatting
Hi all,
My MBP had been running very slow for a while - beachballs, apps taking forever to open etc. So i backed up, deleted the HD and formatted, reinstalled Yosemite (it was running slow on Mavericks also). I only put a few apps back on but its is still as slow as ever. Its a bog standard machine, no upgrades. Any help much appreciated
5条评论
Is this the original HD that was in the system or a replacement drive? If it's a replacement can you give us the make and model info for the drive. Also how much memory do you currently have in the system these newer OS's tend to need a bit more that the baseline of 2GB some of these systems had when new.
由 Dan 完成的
Yes Dan, its the original HD with 249.2gb and 223.56gb free. Its got 4gb RAM and is at 2.7gb when awake with no apps open.
由 asif 完成的
After following the advice of Dan, my MBP which was driving me mad due to its sluggishness has been restored to its former self. I didnt realise that to repair the disk you had to be 'off' that disk. I've verified and repaired the disk and permissions many a time but it didnt speed my MBP up at all. But now its running great. Thanks Dan and ABCellars
由 asif 完成的
Please what do you mean by being off the disc? I have same problem and it is running me crazy. Thank you.
由 KCN 完成的
@kcnw - Think of it this way the cobbler can't fix your shoe while you have it on! This is true with drives as well. You need an external bootable drive running the same macOS release using it to boot up your system to run the needed drive utilities to fix your internal drive. Older HDD's need defragmentation. Both HDD's and SSD's often need a complete wipe and reformat when malware, trojans or spyware are present to fully remove them.
由 Dan 完成的
