跳转到主内容
加入维修社区 - 创建账户
Model A1237 or A1304 / 1.6, 1.8, 1.86, or 2.13 GHz Core 2 Duo processor
External access of MBA HD
I have an HD pulled from a broken up MacBookAir. It uses a special ribbon cable to connect to the LB (?). What can i use to access the data on this drive now that it is out of the laptop. Thanks.
Update
Found the solution here:
http://www.digitalintelligence.com/produ...
If the link doesn't work directly, it's hard to find on the website.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
1条评论
I think LB means Logic Board incase anyone was as confused as I was.
完成的
添加一条评论
8个答案
已选择的解决方案
1.8" SATA-LIF enclosure:
http://www.memoryc.com/products/descript...
这个答案有帮助吗?
得分 2
添加一条评论
最有帮助的答案
Just for the record: The drive is an ATA (IDE) drive and uses a (semi)standard ZIF (Zero Insertion Force) socket. The usual adapters won't do the job.
这个答案有帮助吗?
得分 2
1条评论:
Absolutely correct!
完成的
添加一条评论
Buy an enclosure and put the drive in there. Then you can connect it to any computer with USB, firewire, or whatever type enclosure you purchase.
这个答案有帮助吗?
得分 0
1条评论:
Solution found. See addition to original post.
完成的
添加一条评论
do you want to permanently use the hard drive as an external drive? if so, then yes as rab777hp said just get a drive enclosure to convert it to an external drive
however, if you only need to temporarily access it externally (e.g. you will later re-install it in some computer), there's a more flexible alternative.
get yourself a Newertech USB 2.0 Universal Drive Adapter, or similar product from another manufacturer. This will let you attach any ATA or SATA drive, 2.5" or 3.5", hard drive or optical drive - via USB to your computer. it's a very handy adapter to have around when you're swapping or cloning drives. But as I say, this is only for temporary use, it's not meant to replace an external drive enclosure.
这个答案有帮助吗?
得分 0
1条评论:
This drive is smaller than 2.5. The connector is not standard S/ATA. Its more like the HD in an iPod. It would have to be a tiny ribbon cable. Have various enclosures plus the Newertech device. This HD will not interface directly to any of these enclosures. Thanks.
完成的
添加一条评论
The MacBook Air that I have contains a Samsung HS12UHE
Which has a SATA interface with a 24 pin LIF connector.
I contacted the support for the Digital Intelligence ZIF Enclosure and not only will this NOT work but they do not have a device that will work with this drive.
If anyone has found an adapter that works with this drive please update this question.
这个答案有帮助吗?
得分 0
添加一条评论
I need an adapter as well.
This one here will not work: http://www.adaptare.de/blog/adapter-fur-...
They tell me in the forum that the MacBook Air is the only computer that uses SATA-ZIF at the moment.
Please let us know if someone finds an adapter for SATA-ZIF.
这个答案有帮助吗?
得分 0
添加一条评论
As i stated way above, the enclosure i bought from Digital Intelligence DID work for me. The LIF connector was actually a "VHIF" connector, but it did work.
Bought this one recently
<http://www.amazon.com/gp/product/B001OYC...>
from Amazon.com and it, too, worked on the model of MacBook Air that i had at the time. It was a LIF connection.
---Danno
"May your Mac(s) always start up!"
这个答案有帮助吗?
得分 0
添加一条评论
Does anyone know if the cubeternet enclosure works on zif-24?
Samir
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Danno 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 5
过去 30 天: 36
总计 5,772
