跳转到主内容
Released in August 2012, the Sony HDR-AS15 is as WI-FI enabled HD video action camcorder that features a 1920 x 1080 high definition resolution.
3 个问题 查看全部
Why is my case filled with water?
My camera is soaked when I take it out of the case.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 -1
添加一条评论
1个答案
If you were trying to record underwater, then it might be leaking. Check for any visible damage on the case and the o-ring. If you were not underwater, then moisture may gotten into the case when you were putting the camera inside and fogged up the case. Before placing the camera in the case, make sure you are in a dry area and that no water is in the case.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Justin Calean 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 1
总计 211
