跳转到主内容
The Asus X200MA is a portable touchscreen laptop with an 11.6" display. This device was manufactured in 2014 and is also identified as Asus X200MA-RCLT07.
20 个问题 查看全部
Why won't my screen turn on?
My laptop starts and I can hear it running but my screen stays black.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 5
1条评论
I have the same problem so i plugged in a external moniter and it works so it might rule out the mother board. also while on external moniter i noticed the mouse and touch screen on the laptop work
完成的
添加一条评论
3个答案
已选择的解决方案
This is probably a symptom of a broken screen, it may also be due to a loose connection or issues with your motherboard. Refer our troubleshooting guide for more help on this issue.
Asus X200MA Troubleshooting
这个答案有帮助吗?
得分 0
1条评论:
There's actually no "guide" in your link above. It just stated the cause of the problem but didn't give the troubleshooting steps to be done. I badly need to fix it. More help pls?
完成的
添加一条评论
最有帮助的答案
Also, check the battery, it may not be charged. You might just need to plug it in!
这个答案有帮助吗?
得分 2
添加一条评论
Check RAM
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Luca 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 2
总计 3,287
