跳转到主内容
The Asus X200MA is a portable touchscreen laptop with an 11.6" display. This device was manufactured in 2014 and is also identified as Asus X200MA-RCLT07.
Why won't my laptop charge properly?
I charge my laptop for hours and it shows that the battery is drained or isn't charging.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 10
添加一条评论
3个答案
最有帮助的答案
Vanessa,
First, make sure the charger is completely plugged in. If it is, it may the outlet that isn't receiving power. You can test that by plugging something else into it.
If that still isn't working, you may have to replace the battery. The same thing happened to my computer. Replacing the battery fixed the issue.
I hope this helps!
这个答案有帮助吗?
得分 3
1条评论:
I just replaced my battery. It worked well for nearly a month but now I'm having the same problem. It's plugged in but the battery is not accepting the charge.
完成的
添加一条评论
I have the same problem. I just use my laptop 9 months. but now it's dont want charging (just keep 0%) and the battery indicator flashes. Do replace a new battery can be more durable ? Then how the technic of using the batteries so it's can be durable?
这个答案有帮助吗?
得分 0
添加一条评论
My ASUS R510C Notebook PC does not power up if I disconnect it from my household electrical receptacle. Do I need a new battery
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Vanessa Garcia 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 12
总计 2,159
